401 - 420 of 442 Posts
If things ever get too hot again, install another cooler! :p
I really wonder if the 8 speed could handle that treatment. Its shifting is poor IMO and many time accelerating it flounders wondering what I want it to do. The engine doesn't kick in for 3 or more seconds. I just want it to giddy up and go, unlike the 6 speed which I also have, give it gas and off she goes, gone like one would expect.
Like David was saying, when we tow, I think the best ‘tow mode’ for us is to use manual shift and tell Sorento when to shift rather than expect it to know what to do. We can keep it revving within a range that won’t overheat.
Never driven the 8 speed so I really don’t know what’s it like. However, in theory, I’d like to have more gears so that I can have more choices and possibly improve mpg a bit? As of now, towing has limit my range down to about 180~200 miles(max)! I suppose that’s not too bad because usually it’d Take nearly 4hrs to go that far and I can probably use a break at a gas station.
My reference above is without towing. FYI free unloaded vehicle. Comfort and Smart mode while the SPORT mode is fine but revving higher in all cases than others when cruising.
8 seep does work when towing but I guess it would depend on towing weight. I personally have very light trailer (tent trailer), gross weight is around 2000 lbs. And on a flat terrain it easily stays on 8 speed (no problem at all). My normal towing speed in a range between 100 - 105 km/h (due to trailer limitation). Fuel consumption no more than 12 L, usually between 10.5 -11.5 L. In a city I prefer to switch to Sport mode to have more power but on a highway I have never noticed any difference between ECO/Comfort/Sport modes.
I have to also agree that software for 8 speed is not refined... I've seen a lot of odd behaviours during towing... needles to say "hesitation" drives me nuts... that is why in a city I always turn to Sport mode to compensate it.
When I tow my trailer which is pretty flat with a SxS Atv on it I am likely the same weight. But on non 400 series road so I am not more than 90km/hr with some grades involved. Computer can go to 15km/L for 40km one way tow and reverse of that back home.
I noticed that too. If I go uphill fuel consumption can go over 20, but normally I'm not slowing down... :) The fuel consumption I mentioned is average for one the trip (300-350 km).
my boat trailer LOVES to steal my gas mileage. i get on average 16L/100KM on the highway, and that's even at 90kph. I get better gas mileage in the city then at those highway speeds. Same going down my gravel and dirt roads when I go to my usual fishing spot. It's not like it's a big heavy boat or anything, it's a 14 foot aluminium boat. It's the wind resistance. I should get a cover for when I go down the highway. that would greatly improve gas mileage.
Hmm, it's interesting that most Sorentos that tow are in Canada!
I'm like the only American who uses Sorento to tow. Well, I now live in the pacific northwest... Seattle is very close to Canada. :p
MissingCurlyBracket is like the only other American that I know who tows..., but even you moved northward too, right? Or are you still in Texas?
Moved to Texas, probably will be here a while! But I don’t tow recreationally, just when moving! Good ol’ rentals since no place to store one at the apartment and 2,000 lbs isn’t a lot of weight to play with to begin with!
That 2000 pound rating is one reason I got rid of my 2012 with the 2.4. The turbo, better AWD and the interior is just the icing on the cake for the upgrade. Even though it cost me quite a lot more to go from the 2012 to the 2016 in about a year and a half, i'm so much happier with my 2016.
  • Like
Reactions: missingcurlybracket
Oops, sorry, remembered it wrong. I remembered your journey was a cold one, so I assuming you were moving up! Anyway, 2000 lbs is still not nothing. 1 ton is still significant weight!
Yeah, if it weren't for moving during Covid, I'd probably never attempt to tow anything either. RVing never crossed our minds before. Now as a Washingtonian, it looks like we fit right in as RVers... except most folks don't really tow with Sorentos though. :p
Squeezed in an impromptu camping over the weekend. Glad we caught a sunny day at Mt Rainier before the rainy season moved in… yeah, it’s been raining every day since we got back.
anyway,finally had oil change and front rear differential fluid changed. I think dealer put way too much oil. Above the F line, but clear oil is really hard to see very clearly! ;)
I think I’ll add that Lucas oil stabilizer later if I start to see oil consumption again. Right now there’s just no more room for it. I’ll possibly add a catch can later if oil consumption gets worse?At the moment things don’t look that bad. Thanks for all the suggestions from this thread: Possibly my turn for engine issue?
Lastly I reset my wireless brake controller so everything seems to work fine now. David’s long road trip has gave me some more confidence of venturing out further.
Our Sorentos rock!
Since i have the 2.0 turbo and not the v6, and my limit is 3500 pounds vs the 5000 pounds on the V6, I'm thinking about a 17 foot hummingbird trailer which has a dry weight of 2900 pounds. so once loaded I think I'll be quite close to the 3500 pound with water, propane, food, beverages, etc.... would that be a little too close for comfort?
I like the layout as it's just for me not for me and others. just for me to go into the wilds and spend a few days to a week unwinding without my phone. just to site by a fire, take walks in the forest and go fishing. I don't want to do a tent trailer and I think anything smaller than this 17 footer might be a little too small for me to be comfortable. And I was also hoping to attach a hitch on the back to also tow my boat, but that will definitely go over the 3500 pound rating of the sorento with my little turbo engine.
I was approaching my 5000 lb limit when I was moving from LA to Seattle.
However during normal camping, I'm at around 4500. I have not weigh my TT empty, but supposedly it's at 4000 dry.
Not sure if our cars have the exact same transmission? Structurally, I'm sure 3500 lbs won't be a problem. You should still add weight distribution hitch because you're towing near the limit. Also monitor your transmission temp. On level roads, you should be fine. If things get hilly, then I think you'll likely need a ATF cooler.
Transporting water will be very heavy! If you're boondocking in the wild, yeah, you'll need to bring some water, just don't bring a full tank of water! Try boondocking on your driveway or your yard to figure how little water you can get away with everyday. I'd empty out all of my tanks if I know I'll be on a long mountain pass. Otherwise, I'd usually carry a bit of water just in case wife needs to use the toilet! ;) Anyway, before the actual camping trip, get on a scale to make sure you're within all your limits. Payload limit, each axle, hitch...
Your hitch limit is also reduced to 350lbs, but I'm not so sure that's a hard limit. There's no reason why a V6 engine would all of a sudden structurally beef up the structure to increase my hitch limit to 500 lbs, right? I just think it's way more important to keep hitch weight within 10~15% of your trailer wight so that its sway stable. We don't want to sway out of control!
Bottom line is that based on what I and some others here have done, I think you should be fine. Not sure if you should go nuts like David and go cross country. Just please take things slow and carefully monitor your temperatures. Also, you probably can only pick either the trailer or the boat. Please don't tow both at the same time! :p
The structure of the Sorento itself and the transmission are the same on the turbo and the v6 engines, and I think the 2.4 as well. I believe the 3500 limit on the turbo has more to do with the turbo than anything else, specifically the heat induced into the intake at higher boost applications. The engine is DEFINITELY the limitation with the 2.4 as it lacks the torque needed for anything with more weight.
The last time I towed something that was quite heavy (and maybe up to or slightly past the 3500) the intake temps were quite a lot higher than normal. The intercooler could not keep up unless the ambient air was under 10 Celsius (50 F) at highway speeds, and in city driving the intake temps were even worse. Coolant, oil and ATF temps were steady when I did that towing and were never a concern. Of course, the coolant would warm up faster than normal when I would start but they stayed steadily where they needed to be.
I'm not worried about a weight distribution hitch as I have the airbags. so I'm able to keep the rear from sagging and allow weight to be distributed towards the front.
and about towing both at the same time, I've done that before with other vehicles. my old K5 blazer my parents had as a kid and my c1500 I had multiple vehicles ago I had done that with. I even got quite good at backing up the train of trailers. but it was a much smaller tent trailer so I can see the boat trailer behind it. I know this would be a much different setup as I wouldn't be able to see the boat trailer as much, and turns in the city are not the simplest to take, but once on the highway and heading down the dirt roads it will not be an issue. But since I am doing this to be able to be alone with myself in nature, I might forgo the boat and get a canoe and strap it on top of the Sorento instead. Much easier to launch and land in a canoe by myself than my 14-foot boat and motor.
Yeah, I don’t recall anyone else here who towed with a turbo engine. So that’s something you’ll have to explore all by yourself! :p
Re WDH and airbag, I do believe WDH will actively ‘bend’ the car to dive its nose down so the front axle actually ends up with more load. Airbags merely levels the car, but won’t shift the weight fwd by much. Anyway, WDH is for sure more critical for me since I’m tongue weight is a lot more.
Also I think it’s not legal to have a towing ‘train’ in US? Must be a challenge to setup?
Hey guys, sorry for bumping an ancient thread, but I'm in a bind. Those of you that are towing travel trailers with a 2020 or older Sorento, WHAT BALL MOUNT DID YOU BUY???
I've spent well over 100 hours researching ball mounts, and I haven't found a single one that gives a 10" rise, let alone one that has a 10" rise AND a mount for a sway-control ball. I have a Coachmen 134BHX coming in in two weeks and have no way to hook it up. Thanks!
I got everything from harbor freight! They’re cheap and good and works with my trailer, Gulf Stream 21TBD.
You sure you need a 10” rise?
