Status
Not open for further replies.
Timing Belt Replacement Instructions ( Finally! )
286K views 41 replies 37 participants last post by  dongolf44
#1 ·
On 98 to 2002 Kia Sportage models ( all equipped with the DOHC 16V 2.0 liter 4 cylinder motor ) these are the instructions for the timing belt replacement.
1. Take all frontal pieces off, inculding fan, fan pully bracket, all belts ( A/C, power steering, and alternator ), thermostat housing and and hoses, fan shroud, then crank pully ( 6 - 10MM bolts around a large 21MM center bolt, dont worry about the center bolt, the pully will come off after removing the 6 outer bolts ) then the belt covers, both top and bottom.
2. Once you have access to the belt and with the crank pully removed you will see a small woodruff key on the nub shaft that protrudes from the crank cog. Align that to a 12 o' clock position. This key is what fits in the notch on the crank pully, ignore the small square marking on one of the cog teeth, it is useless.
3. After aligning the woodruff key to the 12 o' clock position make sure your intake came ( left side cam ) is aligned properly, you will know this when you see the "I" on the cog in the twelve o' clock position and aligned with a small marking or "dent" that sits immediately above the cog on the belt backing plate. If it is not aligned there turn the crank another 180 degrees and it should be.
4. Check your exhaust cam the same way as step 3.
5. Now with everything aligned loosen the tensioner nut and pry it to the left with a small crowbar or long screw driver or something elongated. When the tensioner pully is pushed as far as it will go to the left, tighten the nut. This will make it much easier to get the belt off and on.
5. Take the belt off, you may have to work it off with a screw driver or it may simply come off by hand if it is worn well enough. Dont be alarmed if your cams move or snap out of position, it is not a big deal as long as you make sure the crank cog stays put and the engine isnt turned over.
6. Now comes the slightly tougher part, if you got lucky your cams will not have moved, if not then you will have to fiddle around with their alignment and have someone hold them aligned with two 17MM wrenches or something while you reinstall the belt.
7. After installing the belt make sure your alignment marks are set, the "I" on the intake ( left cam ) at 12 o' clock and facing the small dent on the timing cover backing plate and the "E" on the exhaust ( right cam ) aligned the same way as well and your crank cog marking ( woodruff key ) aligned to 12 o' clock and facing the small notch on the front of the block immediately behind the crank cog.
There is also, most times, a small plate on the back of the crank cog that has a beveled notch in it and should be aligned with the woodruff pin, the two parts ( cog and plate ) are one part and move together so if you align the woodruff key at 12 o' clock, the notch should be aligned as well. Now might be a good time to disconnect your battery to allow the cam sensor to reset, it may not be necessary but its better safe than sorry.
8. With all the cogs aligned loosen the tensioner bolt and let it slide back to put tension on the new belt, you may wish to place a small pry bar behind the tensioner to move it to the right a bit and make sure it has tightened the belt securely. Once the tensioner has been moved and the belt securely tight, tighten the bolt once again to hold the tensioner.
9. Turn the engine over a few times using a ratchet and 21 MM socket on the end of the crank cog, making sure to stop the crank after every second revolution and when the woodruff key is aligned at the twelve o' clock position. Then check your markings, making sure they are still aligned, if not, refer back to step 6.
10. After you have made absolutely sure everything is aligned properly, turn the crank until the "E" on the exhaust cam ( right cam ) is aligned at the 12 o' clock position and aligned with the small dent on the belt backing plate. Then turn the engine clockwise until the "S" on the exhaust cog is facing that same dent on the backing plate.
11. Now you may plug all of your water passages and hoses, reconnect your battery, and though it is not advised but sometimes necessary, start the engine. Do not let it run long however, just long enough to make sure everything is running smoothly. If all is well, shut the engine down and make sure the belt is on the pulleys securely and that everything is still aligned as said in step 9, if not, refer back to step 6.
12. Now that everything is running well you may reverse the procedure and put everything back together. After reinstalling everything and starting the engine you may notice a tapping under the valve cover, do not be alarmed however, that is just lifter bleed down from the cams being turned over with no oil pressure. Simply drive the vehicle a few miles and it will eventually go away.
I hope this relieves the pressure on some of you that are trying to find the right way to do this, I have done it this way and I know it works, plus i have the schematics. If you have any questions feel free to post on this topic and ask away, I should be able to answer everything you need.
#28 ·
My wife's 02 Sportage had 155k on the original timing belt, it let go at 80MPH monday on the interstate. Used this writeup as a guide, used the Gates timing kit (comes with water pump, idlers, tensioner, etc), and the car was running 2 hours later. I'm grateful that this particular motor was one of the few (if not only) non-interference Kia motor!
It took me maybe 5 minutes to line the sprockets, piece of cake. I normally do this on Nissan Z cars, where you have to keep 4 of them lined up at the same time, so this was gravy!
Thanks for the good writeup. Its people that take the time to do things like this that make life great for everyone!
#29 · (Edited)
We just put our "02 Sportage back together. It had 107k on it when the original belt started making noise. We followed the instructions, but now have a light that says cam position wrong and it hardly runs. We have replaced belts on a 97, 98 and 2000 and never had this issue before. Apparently it is still out of time. Any suggestions or ideas as to what we may have done wrong? Thank you.
#31 ·
We redid the timing and the same problem is still there. Even though these are supposed to not have clearance issues with the valves, is there a possibility that damage could have occurred? This belt wasn't broken, the one on my 2000 was and runs like a charm after replacing the belt. So confused where to look next.
#34 · (Edited)
In the rear of the head.
That's right.
Have you taken a look at the KiaTech web site? - they have pictures of this.
The camshaft sensor error code is most likely not pointing to a bad sensor, but more likely that the valve timing is incorrect. Check the valve timing again.
Save
#35 · (Edited)
If there was no issue before, and you hand turned the belt BEFORE, trying to start, there shouldn't be any damage.
If you did that, there has to be another issue with what you did.
Hate to say it, but start right over, from the beginning, and redo it.
There can't be any damage, if, the belt didn't break while on, you did it all right, then hand turned it making sure clearence.
#36 ·
Thanks from TGS, go out to the OP of this thread. I needed confirmation on the timing marks.
As long as all marks are perfectly aligned after multiple 360-degree turns of the crankshaft, there's no need to compromise an already worn engine with insufficient cooling, imo, from experience. ;)
#37 ·
The timing was still off, put the belt on and it ran for 1 day. Threw the belt. Replaced the belt, idler and tensioner pulley, threw the belt again. Any other ideas please and thank you ahead of time.
#38 · (Edited by Moderator)
Ok since you came in on this 10-15-2011 with your vech. I did not see except for here now a reference to what you did replace. Lets back up and recap everything first. Then go forward and diagnose.
First time on THIS vech 10-15-2011 not the other ones you owned before. Did you put on a new belt but not the idler and tensioner at 107K? They were reused?
And then on 10-16-2011 took off that same belt and reinstalled it again to make sure it was done right on 10-15-2011? reused ALL PARTS again.
Then on 11-05-2011 came back and told us the belt flew off again the secong time or restated what had happened on 10-16-2011?
Or did you a second time reinstall that belt on 11-05-2011?
A complete job the first time at 107K should have been done with
A new T/B
A new Idler
A new tensioner
Anything less maybe your issue now. It was not done complete and will keep winging the belts off.
Short of that and in case you might have done but did not clearly state it fully. Regardless of what belts you bought for the 97/98/2000 make sure you bought the RIGHT ONE for a 2002 2.0L Sportage. KIA used MANY 2.0L I4 versions not all the same at all. Please do not ASSUME or think if you bought it that it will work 97/98/2000/2002.
And here is why, all belts are not created equal. And all Cam/crank gears are not either. There are no less then five TEETH versions out there being used. Some will work interchangable but not best results for it. And some are NEVE R intended to ever see the wrong engine and pulley sytem for use.
Also the same engine may not even have the same belt all of that model year either. Much less its ten year run 1995-2005. There may be upto and after dates. And ALL parts related to it all. Or running production line updates and recalls/TSB's. Some you might enver see as it was done before you got teh vech new or used. BE CAREFUL assuming things with not checking it all out. Mitsubishi was famous for T/B switches on the same engine with vastly different parts needing to be used. PULLEY/TEETH configuration (some are stronger the the others) were a few of the reasons. A half moon tooth T/B will wing off a V or cut V pulley. And the reverse the the same thing. And there is also a cut half mood too. Putting the wrong belt on will ruin the teeth and no matter how much you reinstall that belt it will wing off time and time again. And it might go on the first time too un-noticed too. And drive you nutz too. Sound familiar? Unless you look real close the teeth fool you alot. And NO the parts places are not foolproof and the first place I do not trust to get the right parts the first time. The dealer however should know better but that is a 50-50 crap shoot at times too. Till the MECH in shop tells the parts grunt this is the wrong belt LOOK IT UP AGIN! And sadley parts stores are never 100% accurate that waht should be in teh box is in the box. THAT is the job of the guy doing the job that does not assume it is. And looks at the parts that came off close and the part going on close. Many times two belts are listed and customer buys BOTH. Takes home and uses what was on it. BUT! one belt was $56 and one $84. And guess which box and which belt gets returned for CREDIT! and restocking that you JUST REBOUGHT. And may not have looked at close and put on your engine. As that is the belt you bought for the 97/98/2002. Why should it not fit.
P.S GATES and GOODYEAR and BANDO and MITSUBOSHI and NIPPON-DENSO do not make all types of tooth belts. And will sell you a belt they make that will work. That, is not the same as the right belt. Just one that will work 95% of the time in thier estimation. OEM is OEM or correct belt is correct belt even if you LIKE GATES! but the OEM one on it is GOODYEAR or the aprts store has GOODYEAR for that app not GATES. And you search high and low for it and buy the GATES anyway mail order from CA and you live in CN.
That was my suggestion to your T/B problem since you asked us.
#41 ·
2006 timing belt
How do I change the timing belt on my 2006 Optima. A step by step was listed in this forum so I would like to know how much difference the procedure will be? It appears as though it is a somewhat difficult and time consuming project.
#42 ·
Sportage Timing Belt
The instructions are referenced with you looking at the engine from the front timing belt broke. Mine has broke twice (usually at approx. 80k miles) and I have replaced it both times with no problems.
Status
You have insufficient privileges to reply here.
