Strange Starting Issue
2.7K views 9 replies 6 participants last post by  1fastkia
#1 · (Edited)
My mother's 2000 Sephia has an odd starting issue.
There are times when the car will not start. Everything turns on (instrument panel, lights, etc), but the motor will not crank.
Come back to it later (whether it be 10 minutes or 4 hours) it will start like nothing ever was wrong. Then it will go weeks or months without an issue. Then it'll happen again.
The only thing we can find related to each issue is that it will occur when she tries to restart the car when it is still hot (e.g.-runs into the store really quick).
Can anyone help find out what is wrong with this car?
#2 ·
I am currently having the same problem with my 2006 Sedona. Only has 3000 miles on it. Same symptoms. The dealer has replaced the Starter....no help. Now they are replacing the relay and fuse/relay box. I have found a consistent behavior with mine. If if fails to start, I can turn the key to the start position and leave it there for 10 to 15 seconds and it will start. Almost like the current heats up the contacts enough to trigger the relay after a few seconds. I hope that the relay is the problem. I'll post again after this trip to the shop.
#5 ·
i would check the starter solenoid, It is possibale its cracked and maybe to much heat is getting into it. Sounds like a problem i had with one of my cars. and i found out it had a little crack in it, I would only have the problems if i drove a very long time or when it was hot out. when it was cool or cold it would be fine all winter to summer hit again.
#6 ·
This happened to my 1999 Sephia. Exactly with the starting symptom you mentioned. It happened over many months, until i developed a fear of not being able to start it at all, somewhere far away. Tick, tick , tick, but no crank. Tried many times, if lucky, it will start in right away.
Now Everything is fine, the engine will start within 0.5 second from ignition key turn as it normally do. Now i fit a remote start system to this nice Kia. Work everytime. This problem happened to me about 2 yrs ago.
The problem was the wire from the ignition key to the starter. You will need to replace that wire, it is probably leaking or shorting somewhere. I spent money for new relay etc but still the same problem. Change this wire, never happen again until today. Cheap solution. The problem was diagnosed by our local AAM (AAA in USA) during outstation when my car failed to start 2 yrs ago.
Try it out.
#8 ·
Update...may be fixed
We got our Sedona back from dealer yesterday. They replaced the Starter two weeks ago but didn't fix the problem. This time they replaced the starter relay and the box that houses all the under hood relays and fuses. We'll see if this does the trick before we try replacing any wiring. I am almost to the point of investigating my rights under the lemon law.
#9 ·
No Joy
Well the relay and relay/fuse box replacement didn't fix the problem. They are now investigating grounding issues. Everything has now been replaced except the wiring harness. I think I have received enough enjoyment from the Kia Service Department here. Time to deal with Corporate folks.
