Just so the forum can decide on your actions about me calling you on your stating untruths as fact and now using you position as a "super moderator" and editing my post.
You should understand the US Constitution and the freedom of expression and press.
If you did not like or condone the comment about the untruthfulness of your evaluation of the "SCANNER" you should supply factual evidence, not censor the post...
Quote from pm
Quote:
I would like to point out that your attitude was not needed. I simply said, your unit was not a full reader and you go off basically saying names ect to me which is not part of the rules here.
If you read my whole post, you would have seen that it says, please do not take offense as I was not having an attitude. YOu cant know someones expression by reading a post on the internet.
I edited out the "bashing" that i saw in that thread.
I did not personally attach you, you should not do that either because someone disagrees with you.
You did , by the way try to discredit my evaluation of a unit that I have, and have used, using anecdotal 3rd party comments from your mechanic who most likely has not seen, and certainly not used the subject unit (Intimating I was not being truthful).
You also gloated that you dont need such "cheap" units as your car runs perfect and if needed you will go use a scanner.
You call this not being personal affront, bashing and an attempt to ridicule me??
Quote:
Mony where my mouth is, dude, you bought th cheap unit not me.
Quote:
Is that link your obd reader? That is just a code reader, and that is it.
LOL where is the display that shows you all the data of the sensors?
Quote:
LOL, show me your obd tool then not a link, hook it up with a video of yourself using it and show us what your scanner is saying.
NOTE all the LOL!
Quote:
I dont want to see a youtube video, like to see your scanner..
My original post was to provide a reasonable solution to members that dont have "Perfect runners" and dont have the advantage of the use of a "Scanner".
I dont see the need for you to scoff at their misfortune.......
BTW, prior to my retirement I was responsible for the running of a fleet of RESCUE VEHICLES (volunteer teams) and they also had perfectly running vehicles..... Without a $4000.00 scanner......Philip
