Background: 98- 2 wheel drive: New Timing belt, tension pulleys, water pump with correct amount of teeth, AC pulley, all 4 new belts, new starter, crank-sensor, Camshaft sensor, Knock sensor, Coil packs not that old. new air filter, valve cover gasket, new spark plugs, new muffler, carrier bearings.....I AM BROKE!!
Previously the car ran fine, it never has missed. This is the reason I bought it, the engine ran like it was perfectly balancing and in time. After the timing belt change, it still ran fine. I did that because I didnt know the history of the car.
After letting the new starter turn for several minutes, the car starts. It idles at the correct RPMs, it sounds find. It doesnt backfire or miss.
But why? Why so long to start it? It wont go anywhere, having to wait to borrow a code scanner AGAIN.
I thought I had gotten some bad gas but since then, ran the Heet engine treatment and added lots more gas to dilute it.
The last 3 codes were:
P0343
P0326
P0117-the thermostat housing plug end was unplugged at that moment
P0343
P0326
