Hello all,
Hope someone can help. I have a 2007 Kia Rondo...34,000 miles. I have a complicated matter and for this I will try to make as much sense as possible. A lengthy question/story so please excuse me for this but it is due to giving you as much detail as possible.
For the past 4 weeks, while driving, I hear a thump and sometimes knocking sound, faint sound, you cannot feel it but can hear it. It happens at speeds of 35 mph or slower and only when starting to come to a complete stop or going over speed bumps ( at slow speeds). It does not happen when I turn corners, although happened once, that is it. Mostly straight driving.
I tested it out and it does the sound more at speeds of 10mph or slower more. I even accelerated quickly and then let go of the gas pedal, another-words force the car to move up and down, as if someone was jumping up and down on the front bumper. This way it made the noise even more noticeable. I took it to 3 different dealers, including Kia... all tell me they see nothing wrong. I had the brakes changed and looked at everything. All good. New brakes, Rotors, everything. Still same sound. \
I looked under the car while I had a friend push up and down on the car, I can hear the sound but everything seems tight. The mechanics who all took a look , checked the suspension, Wheel barrings, Shims, everything.
I also check to make sure it was not something inside the interior that was lose or any toy, change etc. This is for sure a sound coming from the front area of the car.
The car drives fine...No pull, hesitation, nothing. I have 4 small kids and just concerned this may be a sign of something serious. The sounds resembles of something like 2 objects rattling against each-other, or a hammer being pounded on a piece of metal ( faint sound) enough you can hear it.
Should I be concerned? The mechanics, they all told me to wait it out and see if it gets louder or feel the car drive bad. I don't want to wait. Scared my wheels will fall off or something strange.
Is there something else you suggest I look at under the car myself or any symptoms to watch out for to tip me?
Sorry about the length of this. If I knew exactly what was causing it I would've made this more simple...but due to the reasons stated, I have no clue along with 4 other mechanics. I checked throughout the forum and did not find anything to convince.
Thanks so much for your attention and assistance.
Best Wishes,
Anthony
Best Wishes,
Anthony
