Trouble codes P0444 and P0447
8.3K views 2 replies 3 participants last post by  Pacosworld
#1 ·
My 2005 Sedona has these codes and I have to hold the gas pedal down a little and wait 30-60 seconds before driving in cool weather or the engine will die.
P0444 = EVAP EmissionControl System Purge Valve C Open
P0447 = EVAP EmissionControl System Vent Circuit Open
I have replaced the valve-purge control solenoid, the vapor canister vent valve and installed a good used vapor canister. The problem and trouble codes still remain. Does anyone have an idea of what the problem could be?
#3 ·
You may have an issue in the wiring. Its best to start isolating the wiring and test for an open in the circuit.
Save
You have insufficient privileges to reply here.
