spark plug leads
2.6K views 5 replies 5 participants last post by  bombardj1
#1 ·
I have replaced the two long leads on the no. 1 and 3 plugs but the spark plug connectors that are directly attached to the coils are not available separately kia do not list them as a separate part so you have to fork out $50 or $60 each for a complete coil.
I have been told they are available in the U.S. separately.
can anyone confirm this for me?
and give supplier details.
thanks
#3 ·
I need some help with the order of the spark plugs leads. If cilinder #1 is the farthest and #4 is the closest to the front, here is my question. The ignition coil lead on #1 connects to the spark plug on cilinder #4 and the coil on #3 connects to spark plug #2? Ixt is this right?
I really apreciate the help. Thanks
#6 ·
if it was not running, check the timing belt to see if it is broke or stripped ribs, if it is broke and it is a SOHC the motor is toast. if it is a DOHC and a broken TB it should be ok.
