05 Sedona. I know getting to the rear set of three spark plugs is a pain in the neck. Would it be ok just to change the front three? Would this mess anything up or not be recommended/ Thanks in advance!
I knew it would ne expensive thats why I ask about the three. Getting to the back three is hard and the front is easy enough.I just got my spark plugs changed. all 6.
I know I thought like you initially to change 3 in front but then I thought to replace all.
If you go to dealer. I can tell you your expense will be much higher than you thinkk
each sparkplug cost 16 $
16 * 6 + labour = 415 $
Spark plug wires- Need 3 - 21 $ each plus labour (which is ridiculous, you already have intake open , no but they charge again) = 125 $
total 415 + 125
Plus they will for sure add another coil or boot replacement .. Misc 70- 80 $
so rough estimate 415 + 125 + 80
I bought spark plugs from dealer, wres from internet and some cheap mechanic
total 105 + 40 + 200 = 345 $
Hope that helps
