Relay for OEM fog light upgrade - 2013 Sportage LX
2 reading
8.4K views 11 replies 2 participants last post by  barry_mcki
#1 ·
Anyone know where I can get a relay with a dual 87-pin output and a built in fuse? I've looked all over the internet and found only the 5 pin with 87 and 87a. I would prefer to drive these OEM fog lights with individual terminals on the relay.
#4 ·
Sorry if I confused you M-007, but NARVA don't make a fused dual pin 87 relay, the one's I have used are single output with a joiner or double headed crimp connector, something like this:
You can find NARVA products on eBay, however your local auto-shop should carry a brand that is a little cheaper and easier to supply. NARVA is a brand that is readily available for us down under so I refer to it, but because we live out of town I tend to buy things like relays and crimp terminals in bulk on line.
Reference:
Normal Open 4 & 5 - Products - Narva
Fused - Products - Narva
Narva Relay | eBay
#8 ·
The 27w is the original fog bulbs, so that's between 2 and 2½ amps per fog line being drawn down, total 4 to 5 amps thru the relay contact (pins 30/ 87) if you were going to stay at that size. So yes a single 30amp relay would handle it okay.
A 12v relay coil (pins 85/86)will draw between 100 and 300mA so by tapping this into the low beam line you are increasing the current draw of that low beam by this amount.
Low beam bulbs are 55w, about 4 to 4.6amps, so increasing this load by another 100-300mA is pretty significant, but without the relay you are adding almost 50% more current drain on the low beam circuit, this is why we say it is always better to go that extra step in adding a relay.
If you have wired the contact side of the relay (pin 30/87) to the battery and load (via a fuse) you can increase the light power up to about 180w each side and still remain in spec on the relay heavy duty contacts(30/87) and the coil side(85/86). Of course the wires from that battery need to be rated accordingly to cope with this load.
#10 ·
Personally I think its a bit of over-kill. It's not as if you are drawing a lot of current or that it is an essential accessory (is there such a thing as an "essential" accessory ?), so unless you feel like doing extra work - and introducing more points of failure - there is nothing wrong with just one relay.
#12 · (Edited)
The fuse rating is to match the load you are pulling, i.e. if you are installing two 27w lamps, the current draw (load) is these two combined (54w).
Power(P) in watts is calculated as voltage(V) times current(I) in amps; [P=VxI], so to work out the current we divide the power by the voltage.
So this gives 54w÷12v = 4½amps (the car's voltage will change depending on revs and battery condition etc. , i.e. if you calculate using 13.5v the current works out at 4amps, 0.5 amps less, 11.5v is 4.7amps)
Fuses come in different current ratings so in our case we'd be looking at fuses in the range between 4, 5, 7½, or 10. I would use either the 7½ or 10 amp depending on what I had handy, doesn't matter that it's a bit more, however 4 is definitely too small, and 5 is cutting it fine if your voltage drops below 12v (say at idle or if the motor is off).
BTW the 40amps of the relay is the maximum the contacts of the relay is designed to take, so whilst you can use it on your twin 27w fog lights, this same relay with a 40amp fuse can handle twin spotties of up to 240w each (480w total) at 12v. You would need to make sure all other components in the system were also suitably upgraded especially the wiring and connectors/terminals.
