Headlights not working. Kia Cerato ex.
19K views 3 replies 2 participants last post by  tammy607807
#1 · (Edited by Moderator)
I have the same car, Kia Cerato Ex 2005 model. The headlights (bigger ones) are not working. While the smaller lights are working fine.
I understand from this thread that there are 3 components that might have failed;
Fuses
Relays
Bulbs.
Where can I find the fuses and the relays?
Are the fuses near my steering wheel?
Is there any electrical wiring diagram available anywhere? I bought the car second hand and I dont have the user manual.
Thanks in advance for your kind advice and help.
#2 ·
tammy607807...
Hello...and WELCOME to kia-forums!
My 06 Spectra is the same model style so I should be able to help you.
On my car with the hood/bonnet up on my car on the right side is the battery. Right behind the battery is a black box...this is the under hood fuse box. There are two release clips you push in and then you lift the lid/cover. If you look on the inside of this cover it shows the relays and the fuses for the headlights. I don't think it is the relays probably either the headlight bulbs or the fuses that protect them.
Keep us posted on what you find...
Save
#3 ·
Could not repair the issue.
Thanks for your reply.
I opened the relay/fuse box and found the fuses & relays for the HDLP (guess it is the high beam) and for the LDLP(guess it is the low beam).
I swapped the fuses and the relays between the HDLP and the LDLP.
Still when I switched on the lights, only the smaller lights were on in both the cases (when I swapped the fuses/relays).
I will try one more time and if cannot get it right, I will bring it to the workshop.
Thanks for your kind help and advice.:D
#4 ·
Thanks for your advice and help. The bulbs were the culprits. I changed the bulbs and everything is fine. Thanks for your replies and help.
You have insufficient privileges to reply here.
