Fitting flip down DVD player
5.3K views 2 replies 3 participants last post by  Electech1
#1 ·
Right, from what i gather a DVD player can be added to a 2005 Sedona by removing the plug in the roof lining and attaching the mounting place to the roof bracing.
However, im looking to get a screen with a built in DVD player to save having to run wiring down to underneath the seats. Instead, can you splice into the wiring for the rear courtesy lights (to pick up +12v and ground)?....It'll save having to drop the roof lining (and time)
Ta
#2 ·
done mine with built in dvd flip type roof mounted...use existing speaker and link the video input to the reverse camera monitor which mounted at the front
#3 ·
Yes, you can just pick up 12 volts under the head liner. I picked up the 12 volt line that runs just above the door. Just pull down on the headliner after you remove the handles etc. There are a couple larger gage wires running there, that is what I used.
I mounted the player to the same bracket that the liner plug came out of.
I only use the wireless head phones I did not hook up to speakers at all.
You have insufficient privileges to reply here.
