Hi all,
I have a Kia Sorento 2011 LX 4 cylinder. I've been having the check engine light for a couple of months and its showing P0455 (Large Evap Leak). I've changed the fuel filler neck because it was rusty, then the purge valve, Canister valve, fuel pump, the seal and the fuel pump sensor. However, the check engine light still comes out. Do you have any suggestions what I can do about it or if there are any other reasons?
Thank you for your help.
