The timing belt on my 2000 Sephia broke last night. I've done my homework, so I'll spare the two obvious questions... I understand, or at least hope this is a non-interference motor, so I am going to change the belt myself and not worry about the valves. I know where the timing marks are and how to change the belt itself. I've done it before on Hondas which were dohc, but they had distributors. That leads me to my question... How do I tell if its not completely out of time before I fire it up? I'm used to finding tdc, lining up the pulley marks, and then making sure the distributor is pointed toward spark plug wire #1 . What do you do in a coilpack car? Will the cam and crank sensor tell the computer what to do, or is it possible to set it 360 degrees out of time?
