Hello all, been trying to troubleshoot my 2016 Sorento No Crank issue. I’ve tested Battery(Good @12.6V) Threw in a new starter(thought I had narrowed it down to a bad solenoid) with no luck. Currently, when you turn the key, I get a single click which I have narrowed down is coming from the ICM, little yellow module mounted to the side of the blower motor case behind the glovebox. I do not have access to reliable wiring diagram to trace for power. I get no relay clicking from the junction box under the hood nor does the starter solenoid make any kind of noise when turning the key. Anyhow, thanks in advance for anyone’s input!
- Engine: V6 - 3.3L 3342cc GAS DI vin 5 - 4 valve DOHC
- Submodel: LX
- Drive Type: 4WD/AWD
- Body Type: Sport Utility
