2014 Sorento V-6 Engine Under-Hood Connectors CHEAP!
6.2K views 11 replies 4 participants last post by  pnoman
#1 · (Edited by Moderator)
Back in early 2017, my mother's 2014 Sorento LX V-6 was the victim of several starving rodents while parked down at the creek at our farm. The rascals chewed thru the main engine wiring harness (and 2 other ancillary harnesses under the hood and firewall) in about 10 places, rendering the vehicle undriveable. State Farm paid for the $7,700 repair, which took 3 weeks.
The KIA mechanic (a top-notch, trustworthy guy!!) gave me the old wiring harnesses in a box and I stuffed them in the garage and forgot about them.
Last year, my mother passed away and we sold the Sorento. Rather than throw away the wiring harnesses, I cut off every sensor and connector with as much lead wire (for easy splicing) as possible. There are probably 25 or 30 connectors in the bag now. Takes up 1/10 of the space as the box.
It turns out KIA does not sell a lot of these connectors separately - rather, you must buy the entire harne$$. Ouch! I already helped out one guy who had a high-pressure fuel pump wire and connector eaten. Sent him the connector and saved him almost $2,000.
* If you are the victim of such critters and find yourself needing a connector from under the hood, contact me and if I have it, I will mail it to you for just the cost of shipping. Make sure you describe where it was located and clear, up-close photos will help ALOT! *
Just trying to help out. BTW - I don't get on this forum as often now, so give me a few days after posting to check. Thanks.
Photos posted below in Posts #3 and #7.
#3 · (Edited)
I will try to post a few photos:
Sorry - I can't seem to post photos but can attach thumbnails below. Click on them for full size.
#4 ·
Bump
Just bumping this back into view since it's critter season.
If anyone had a hungry varmint chewing on engine bay wiring, let me know if you need a connector so you don't have to buy the entire wiring harne$$.
Came off a 2014 Sorento with V-6.
#5 ·
Semi-annual bump in case anyone else's Sorento got "eaten".
BTW - I don't check this every day (sometimes not every week) so please be patient if you respond. Thanks.
#6 ·
It is not new issue for anyone who is leaving their vehicle standing for a length of time. If there are known rodents, squirrel etc around one of them will eventually investigate the housing condo offerings within and if, as in KIA (not unique to them, many oem are having this issue) use Vegetable oil based insulation for the wiring. Housing with food already there becomes a wild animal party. You nor anyone else is driving anywhere. Vehicles need to be parked where its unlikely they'll venture and/or garaged at least if gone for 2 weeks or more.
Until Vegetable oil is stopped being used by the harness manufacturers this will be an on going issue for all owners. NOT JUST KIA'S.
#8 · (Edited)
,,,If there are known rodents, squirrel etc around one of them will eventually investigate the housing condo offerings....
How about a cosy wife's SUZUKI sx4 HVAC intake air filter for a mouse....
113829
#7 · (Edited)
To hopefully make this easier for requests, I took photos of what I have. Hope this helps.
If you recognize the piece you need, use the photo to reference it to me. I can also take a closer-up photo to verify if you need.
Thanks.
#1 - Fuses
#2 and #3 - connectors around engine
#4 and #5 - connectors around fuse box
(Click on thumbnails for full size photos)
#9 ·
Air conditioned and fresh air for them. LOL
#10 ·
Rummaging through the garage this week and came across the box of wires, so I thought I'd give the thread its annual bump.
I still got 'em if you need 'em. Since I don't have the Sorento any more, I don't get on here often, so be patient. Thanks.
#11 · (Edited)
Bump for the new folks. See Post #7 (above) for photos of what I have.
If you had rodents eat through a sensor/connector and don't want to spend out big bucks for the entire wiring harness, maybe this will help.
Reminder - these are free. Just send me enough for postage. PM me if you need one.
#12 ·
Annual bump in case anyone had a critter under the hood and needs a connector - I still have them.
Photos on Posts #3 and #7 above. Free - I just ask that you cover postage.
