2013 Kia sorento UVO no amp/nav pinout diagram
14K views 8 replies 3 participants last post by  jdunk54nl
#1 ·
Hey All,
I am trying to find the pinout diagram for a 2013 kia sorento with the uvo radio with backup camera but no navigation and no amplifier. I can't tell if it is the same as the non-uvo radio pinout or not.
Does anyone have these or can direct me where to find them online, I don't mind paying a small fee for a site that has them, but I couldn't find out for sure if any have this particular one or not.
Thank you for the help!
Jacob
#7 ·
Ya, I installed an aftermarket speaker system with dsp (kind of REALLY into audio) and noticed the radio between digital and FM has the polarity on the speakers swapped. As well as the length of time it takes to connect to my phone via Bluetooth or USB. Also the USB just disconnects after a few minutes anyway :rolleyes: I can't stand it.
I am replacing it with a Kenwood dmx-957xr and want have an extra idatalink maestro rr. I sent this info to idatalink after being told their hk1 harness wouldn't work. But it should. If they don't respond, I am going to try to flash it with the 2014 firmware to retain all of the options you can with a 2014. Should be no reason why that shouldn't work....
The normal 2013's have a completely different wiring setup and I understand why they don't work. But the UVO seems to have the newer style.
#8 · (Edited)
Got the new radio installed. Here is what I used
Idatalink Maestro RR
, Idataline Maestro hk1 harness, Kenwood DMX-957xr, Metra Dash kit
I was told the hk1 harness would not be compatible with this 2013 model year. It works flawlessly so far. I retained everything including the backup camera. I installed it exactly the same way as a 2014 kia sorento without amplifier. I even flashed the maestro rr with 2014 kia sorento information since there isn't any for 2013.
I installed the idatalink uhk1, but apple car play would not work with this, so I am going to remove it, gut the factory location and install a flush mount USB and aux input:
This was based on this video
Original equipment:
Installed:
#9 · (Edited)
