2001 Sportage power loss
6.5K views 9 replies 6 participants last post by  sunrise2302
#1 ·
Hello all. I have a 2001 Sportage that a couple months ago started to lose power. It has gotten progressively worse to the point of barely getting up to the speed limit. So far I have cleaned the MAF, new plugs (ones I took out looked good), new air filter, checked timing belt (timing marks line up), new fuel filter, new fuel pump, fuel pressure regulator, new catalytic converter, crank position sensor, cam position sensor, TPS, 02 sensor. None of this helped. Vacuum is good. I did a compression test and was 140, 128, 130, 128. I even pulled the valve cover checking for a wiped cam, but it looked good. I have a good ground from the battery to engine (.5 ohms). It is not missing and idles and runs smooth, just no power. I don't know what else to try. Any ideas of what to do next? Thanks.
#3 ·
Thanks for the response. I assume by installing a pressure gauge in the 02 port you are checking for exhaust restrictions. I currently haven't put the exhaust back on the car other than the new exhaust manifold and new converter which bolts directly to it. I've been pulling parts off of a wrecked 2000 sportage. The one thing I haven't swapped out is the MAF, although I unplugged it and took it down the road and had no change in performance. When I get back to the wrecked sportage Thursday, I will pull the MAF and swap it with mine. To add some history, I did get a tank full of bad gas in the car about 6 or 8 months ago. Had about 3 gallons of water in the tank. I pumped and cleaned the tank out and changed filter, and after a couple days it finally quit sputtering and has ran fine until now. This thing just won't rev. In park at WOT in only hits about 4500.
#4 ·
.... I did a compression test and was 140, 128, 130, 128. ....
I'm not familiar with this vehicle, but generically even 140 sounds low to me. However, I certainly could be wrong about that. Do you have the compression range specified by Kia? If not, perhaps someone else knows what it is. In any case, the high/low differential is pushing the generally acceptable 15%, so that's a bit of a red flag. Did the values change wet versus dry? (assuming that you did that extra test).
#6 ·
I'm going to redo the compression test. Was raining and I was working on it outside and was rushing. I don't have the long metal tube adapter to get all the way down through the valve cover to the plug holes, so i was trying to turn the rubber line to tighten it up enough to get it to seal. I had to make several attempts on some cylinders before I got readings above 50 psi. Also not sure I let the motor turn over 5 times on each cylinder. I'm hoping for better results this time. With the fuel problems I had in the past, I'm going to pull the fuel rail and test, clean the injectors while I can get to them also. This thing has 170K on it, but its in better condition than most of these that I've seen, and it's been a really dependable little SUV right up until this started. I'm sure a lot of people wouldn't put much effort into a Kia this old with this many miles, but I like this little ride and I'm not going to give up on it yet. I hope to get all this done as well as get the other MAF put on Thursday. Will post results, and once again, Thanks.
#7 ·
Just a hunch, but did you check the air inlet & tubing from the radiator to the air filter? I had some acorns in there one time, in went the mothballs! ;)
#8 ·
Update. Bought a new compression tester. Results with cold engine dry test. 176. 60, 175, 172. I made several tests on number 2 cylinder. First test was 110-115. Then 3 consistent of around 60 psi. So now to find out where its going. I don't have a leak down tester, So this will be a good excuse to buy one.
