Hello all. I have a 2001 Sportage that a couple months ago started to lose power. It has gotten progressively worse to the point of barely getting up to the speed limit. So far I have cleaned the MAF, new plugs (ones I took out looked good), new air filter, checked timing belt (timing marks line up), new fuel filter, new fuel pump, fuel pressure regulator, new catalytic converter, crank position sensor, cam position sensor, TPS, 02 sensor. None of this helped. Vacuum is good. I did a compression test and was 140, 128, 130, 128. I even pulled the valve cover checking for a wiped cam, but it looked good. I have a good ground from the battery to engine (.5 ohms). It is not missing and idles and runs smooth, just no power. I don't know what else to try. Any ideas of what to do next? Thanks.
