Status
Not open for further replies.
Need A Straight Answer...PSF3
101K views 10 replies 7 participants last post by  FDE
#1 ·
I've searched the internet and this forum however I have not found a clear answer for what should be a simple job; that of topping off my power steering fluid with what KIA calls PSF3.
Some sources say it is regular power steering fluid, others say it is ATF, while others say it is an unobtainable fluid KIA # 03100-00100.
Help....I just want to top off the fluid with the right stuff as it is approaching the low mark. :eek:
#2 · (Edited)
PSF-3 is a Hyundai fluid specification that pre-dates Hyundai's acquisition of Kia from Ford. If you were pull out the lube chart printed in the owner's manual of any Hyundai vehicle manufactured during the mid-to-late 1990's, the power steering fluid would be listed as "ATF Dexron II, PSF-3 type fluid". The original PSF-3 product was Dexron II. True D-II is getting harder to come by, but Dexron III was formulated to be backward compatible with systems originally using Dexron II.
#7 · (Edited)
A little off topic, but I think Ford was merely one of the share holders of Kia, and Hyundai didn't actually buy Kia from Ford ?
BBC News | The Company File | Hyundai wins Kia auction
Personally I'd stick with what Kia spec, and if unsure, play safe and buy it from them.
Important to find the leak !
Save
#8 ·
PSF3 is similar to generic power steering fluid. I have used it as well as dexIII to top off with in my own Kia vehicles. PSF4 is different and is only called for in a few specific vehicles. It is an extreme pressure fluid with a different viscosity than the other stuff, not compatible.
Status
