I really don't like the giant KIA emblems and since I was awaiting a wiring harness for my DRL/Halo project I started to wonder....
Since there is only options for the large size emblems come with a black inset color I ended up testing out something of my own. This is the flying "K" without the graphic insert removed, then with something special added.
Check out the test run:
The only problem I have was some heat gun damage on this one and surface scratches on that other - lessons learned. If not for that I think this would be on the front of Ruby this weekend. Now to scrape up some cash to get some more of these to prove it out further.
Some things I needed to consider:
1) Refining the process that makes the magic happen. It's not perfect but I think I can get it better.
2) Finding the best topcoat, UV proofing the color. It's got to hold up.
3) Is the purchased emblem going to hold up or should I do something else? They are so expensive.
4) What if the emblem design was different? Cheaper better?
...just rambling, not sure where this is going to go.
