1 - 7 of 7 Posts
Have a 2.0l cvvt motor out of a 2006 or 2007 (not sure) kia spectra5 and still need a few parts before I put it into my accent...
1) Mass air flow sensor
2) Upstream and downstream o2 sensors
3) Oil control valve
4) Canister close valve and electrical connector it plugs into and about half foot of wire, all hoses, and plastic cover and metal bracket that supports the plastic cover..
5) Fuel tank pressure sensor, vapor lines and T fitting if there is one, and electrical connection with half foot of wire....
PM me or shoot me an email at [email protected]
You are going to need MORE parts than that...
You will need the full harness... The ECM... and supporting circuitry.
Lots of splicing and rewiring and probably a lot of CELs when/if you do get it running.
The parts you want should be available at your local bone-yard.
I have a friend who has an Accent with the Beta2 engine. It's a fun little car to drive. I believe it is also pretty much a drop in deal too. You will need an ECU or some kind of stand alone engine management unit.
Yea its a pretty well documented swap with many successes....I have the harness and ecu already, but im just going to redo the pinning on my harness plug and add a few wires...I need the CCV and FTPS to avoid the CEL...
Not the best way to start a swap, unknown status LOL.
1 - 7 of 7 Posts
