2011 Sorento EX 4cyl 2wd w/ 53k miles
sudden and very temporary loss of engine power, usually while at cruising speed on freeway - sometimes the engine light flashes for a second, sometimes the immobilizer light flashes (image of a key inside vehicle), sometimes the traction control light flashes (or more than one) as i feel a jolt as if brakes suddenly applied or fuel supply interrupted, tachometer drops suddenly, forward momentum slows, and then things return to normal after a second or two. This happens irregularly, sometimes not for an hour, sometimes 10 times in a 20 minute drive. Its unnerving and unsafe, as my car suddenly slows without the brake lights illuminating.
This has also happened a few times under acceleration from a dead stop (which has me worried about getting rear ended) The car has recently also seemed to shudder while decelerating approaching a stop light, and has actually stalled once in that situation (this is an automatic transmission)
The car has been seen by the dealer at least 4 times for this now, and last time replaced the ABS module - which didn't change a damn thing. No error codes are being thrown and no error light remains illuminated. Any ideas much appreciated!
