41 - 60 of 69 Posts
Hi, i have this problem and i can't find the meaning
Hi people,
I have one Sorento Limited 2002, and some times this light turn on and then turn off, but i don't find the explanation in the work shop manual.
Please review the picture in the attachement.
any help why it appears and disappears...
I find it hard to believe that Kia has a 10 year or 100,000 mile warranty . Bet it does not cover electronic modules and other electronic stuff . on Mine the door ajar light is also going off and then the dome light went and diode . then when making turns the beeper goes off . To many senors that are not needed and electronic junk .
2016 Soul SX 2.0L - Caribbean Blue
power train only and to the first owner. :)
2005 kia sorento
sir good day i need your help. i need this workshop manual for repairing my 2005 kia sorento. this could be a big help... thanks
Sorento 2.5 diesel
Hello, I'm after a workshop manual to analyse the A/C on my UK Kia Sorento 2.5 diesel. Mainly the wiring diagram so that I can check which sensor or switch is blocking the A/C operation. I had it recharged and they say it pressure tested ok and took the charge. But when I check it there is no power to operate the clutch. Before I take it to a specialist I want to diagnose it myself to avoid being charged for a new compressor when it might just be a switch, sensor or relay! The relay is not being operated.
I've tried all the links here in this post but none work. As this is the first sticky link I was expecting one might work? Or have the all been blocked?
Thanks in advance from a virgin newbie.
Sorento
Can someone email me the shop manual for KIA Sorento. Having trouble getting past media fire entry. I set up media fire but when I tried to enter the password I used to set up the acct, "wrong pass word" bs. But when I enter 4digit acct code opens but I can't xfer the manual.
Email: [email protected]
GREATLY appreciated.
Kia Sorento
the link i sent works. just highlight >
mediafire.com?iiw7cpircrdx3an
and right click then select> go to mediafire.com?iiw7cpircrdx3an (if you are using Chrome) and it will open a page with direct download. NO LOG IN REQUIRED.
Email requests are usually spammers, thats why I dont bother.
kia sorento ex 2008
The link doesn't work, I tries it, it redirect me to mediafire site but nothing there
please I really need the Workshop Manual Sorento 2003-2010
Kia Sorento
the other link sends you to this link. And this works. If you cant get it to work then you need to install AdBlock or something because I dont have any problems and sends me to the correct page. Good luck.
2005 Kia Sorento 3.5 LX
Aloha, I am in need of some information. New (used)2005 Kia Sorento. To be concise....just wanted to replace my leaking valve cover gasket and now I have bent valve(s)!! Any thoughts, suggestions, advice would be greatly appreciated. Mahalos :(
41 - 60 of 69 Posts
