2011 Kia Sorento
Remote Start
Item Wire Color Polarity Wire Location
12 Volts red (40A) + ignition switch, black 6 pin plug, pin 1
On vehicles with Smart Key, this wire is in the driver kick, white 15 pin plug, pin 11.
Second 12 Volts pink (30A) + ignition switch, black 6 pin plug, pin 5
On vehicles with Smart Key, this wire is in the driver kick, white 15 pin plug, pin 12.
Starter green + ignition switch, black 6 pin plug, pin 3
On vehicles with Smart Key, this wire is red (+) at the dash fuse box, white 8 pin plug (C), pin 4.
Second Starter black/orange and pink (push-button start) + start/stop button switch, black 10 pin plug, pins 1 and 7
Ignition orange + ignition switch, black 6 pin plug, pin 4
On vehicles with Smart Key, this wire is green (+) at the dash fuse box, white 8 pin plug (C), pin 3.
Second Ignition N/A
Third Ignition N/A
Accessory blue + ignition switch, black 6 pin plug, pin 2
On vehicles with Smart Key, this wire is at the dash fuse box, white 8 pin plug (C), pin 2.
Second Accessory yellow + ignition switch, black 6 pin plug, pin 6
On vehicles with Smart Key, this wire is at the dash fuse box, white 8 pin plug (C), pin 1.
Third Accessory N/A
Keysense yellow - ignition key switch, white 6 pin plug, pin 4
On vehicles with Smart Key, the key fob holder sense wire is red at the dash fuse box, rear, white 16 pin plug (MM), pin 8.
Data Bus blue/orange or blue to red (immobilizer data) data passenger kick, green 18 pin plug, pin 18
The immobilizer light wire is brown/orange or brown (-) in the passenger kick, green 18 pin plug, pin 17 (without Smart Key), or instrument cluster, black 12 pin plug, pin 5 (with Smart Key).
Can Bus High white (C-CAN) data data link connector, black 16 pin plug, pin 3
The B-CAN high wire is blue at the dash fuse box, rear, white 16 pin plug (MM), pin 5.
Can Bus Low red (C-CAN) data data link connector, black 16 pin plug, pin 11
The B-CAN low wire is red at the dash fuse box, rear, white 16 pin plug (MM), pin 6.
Can Bus Sw N/A
Power Lock blue/black - dash fuse box, white 26 pin plug (FK), pin 4
Power Unlock gray/black - dash fuse box, white 26 pin plug (FK), pin 24
To unlock the driver door only, use yellow/black (-) at the dash fuse box, rear, white 16 pin plug (MM), pin 2.
Lock Motor orange 5 wire dash fuse box, white 39 pin plug (A), pin 16
Driver Unlock Motor green 5 wire driver kick, door harness
Parking Lights (-) blue - headlight switch, white 13 pin plug, pin 2
Parking Lights (+) green (L), yellow (R) + dash fuse box, white 39 pin plug (A), pins 11 and 7
Hazards yellow - dash fuse box, rear, white 16 pin plug (MM), pin 10
Turn Signal (Left) white (F); white (R) + dash fuse box, red 20 pin plug (F), pin 10; wht 39 pin plug (A), pin 14
Turn Signal (Right) yellow/black (F); pink (R) + dash fuse box, red 20 pin plug (F), pin 20; wht 39 pin plug (A), pin 13
Headlight blue - headlight switch, white 13 pin plug, pin 4
AutoLights green (interrupt to turn off autolights) - headlight switch, white 13 pin plug, pin 3
Reverse Light red + dash fuse box, white 39 pin plug (A), pin 15
Left Front Door Trigger green/orange - dash fuse box, white 26 pin plug (FK), pin 10
Right Front Door Trigger pink/black - dash fuse box, white 26 pin plug (FK), pin 18
Left Rear Door Trigger white - dash fuse box, white 26 pin plug (FK), pin 7
Right Rear Door Trigger gray/black - dash fuse box, white 26 pin plug (FK), pin 5
Dome Supervision brown - left front pillar, white 22 pin plug, pin 1
Trunk/Hatch Pin yellow/black - dash fuse box, white 26 pin plug (FK), pin 19
Rear Glass Pin N/A
Hood Pin red/black - dash fuse box, red 20 pin plug (F), pin 16
Trunk/Hatch Release yellow/black - dash fuse box, white 26 pin plug (FK), pin 11
Meter this wire while opening the liftgate from the handle on the rear of the vehicle.
Trunk Release Motor blue + dash fuse box, white 39 pin plug (A), pin 26
Fuel Door Release blue/orange + driver kick, door harness
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm brown/orange and gray - and open dash fuse box, white 26 pin plug (FK), pins 21 and 26
Meter these wires while turning the key in the driver door key cylinder. See Tech Doc 1300 for wiring information.
Factory Alarm Disarm pink and gray (double pulse) both - dash fuse box, white 26 pin plug (FK), pins 9 and 26
Disarm No Unlock see factory alarm disarm
Trunk Alarm Shunt N/A
Tachometer NOT orange or pink/black ac any fuel injector
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal black (in), white/orange (out) - N.O. clutch switch, white 2 pin plug, pins 1 and 2
Fuel Pump blue + dash fuse box, white 39 pin plug (A), pin 30
Rear Defroster gray - latched dash fuse box, red 20 pin plug (F), pin 17
Mirror Defroster same as rear defroster
Left Front Heated Seat yellow + latched driver kick, blue 22 pin plug, pin 15
Right Front Heated Seat yellow + latched passenger kick, yellow 22 pin plug, pin 19
Speed Sense brown ac data link conn, blk 16 pin plug, pin 6 or radio, gry 8 pin plug, pin 1
Brake Wire yellow (2.4L), green/black (3.5L) + brake switch, white 4 pin plug, pin 1
Parking Brake gray - dash fuse box, white 26 pin plug (FK), pin 6
Horn Trigger gray/black to gray - driver kick, white 15 pin plug, pin 6
Wipers green (L), pink (H) + wiper switch, white 14 pin plug, pins 3 and 9
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
the12volt.com
