can you add option like mood lightning in the radio with engineer mode ?Sure it is;
Model: MQ4AH.S5BLC.AEU
Software: MQ4_H.EUR.S5W_L.001.001.200612
Firmware: MQ4_H.EUR.03.200420.MICOM
Nav App: STD5W.EUR.KMC.200423.8af9db6
I went in the engineer mode and saw the wifi system in there just not activated, which is pretty frustrating.
Also having weird issues with my aircon randomly blowing out different temperatures to different sides of the vehicle even when everything is synchronised at a set temp, one side will blow cold and the other side will blow hot and then the back will randomly do something else!
Are you sure it's MQ4_H.EUR.02.200720.MICOM and not MQ4_H.EUR.03.200720.MICOM?Software: MQ4_H.EUR.S5W_L.001.001.200923
Firmware: MQ4_H.EUR.02.200720.MICOM
I have the Samsung S20 FE and it fits perfectly fine.I wonder if the new Galaxy s20 FE or s20+ will fit into the charging pad holder. I have a 2017 sxl but my new S20 FE phone is too big for the charging pad, Same thing with my wife's 2020 Sportage the phone wont fit.... Bummer.
Would it fit if you used a cable with 90 degree ends?It only fits without a USB connected. My older Galaxy S8+ fits in my 2020 Sorento charging pad, but barely. With a USB plug of any kind connected, no go. I'm shopping for a new phone in any case, the S8 line doesn't have wireless Android Auto, and I'm hoping to get that working when AAWireless poops out their wireless adapter for the car.
Nope, I bought two types of those, one is a 90 degree just like your picture, the other is a 180 that takes the cord behind the phone. Both took too much space and didn't allow the phone to lay flat. Since it was actually putting pressure on the USB connection to the phone, that's the worst possible thing to do, that's what kills that jack.Would it fit if you used a cable with 90 degree ends?
For my '17 Sorento (pre-wireless charging as an option), I ended up buying a wireless cradle that plugs into the cig lighter port and rigidly snakes up to the passenger side of the A/C controls. Look on Amazon for "B07Z37GX5C" - it has the added advantage of putting your phone up at a reasonable height so you can see the display.Nope, I bought two types of those, one is a 90 degree just like your picture, the other is a 180 that takes the cord behind the phone. Both took too much space and didn't allow the phone to lay flat. Since it was actually putting pressure on the USB connection to the phone, that's the worst possible thing to do, that's what kills that jack.
The Galaxy S8+ has less than 1/4" of play when laying flat in the box, and there's no USB cord that I've found that has a small enough protrusion to solve the problem.
