Help!! I live in Seattle, and a clean windshield is a necessity with all the rain and road spray.
My 2008 Kia Spectra 5, 2.0L
Recently I've found that my windshield washer pump has stopped working. It has fluid, the fuses are good, and when I pull back on the pump control the wipers run. There is no noise coming from the pump. Normally I can hear it running.
I probably need to replace it, but I don't know where it is located, or how to remove and replace.
Any suggestions?
It is located on passenger side inside of fender, close to the headlights. Remove wheel, then there are about 10 screws that hold the inner fender on. You only need to remove enough screws so you can bend the inner fender back. I had to replace mine also. They are reasonably priced thank goodness. You ight want to disconnect the hose going to the nozzels and blow some air thru to make sure they are not clogged.
https://www.kiatechinfo.com/viewer/...^ENG^KM^LD13^2008^all^0^none^none^none^shop^$
Thanks man!
Hey KIAZILLA!!
Thanks so much for the info!! This is gonna save me a bunch of cash! I really appreciate your help!
