1 - 7 of 7 Posts
I searched for almost an hour under the vehicle (KIA Sportage 2008). Can someone please help me point out in the right direction?
Memorial Super Moderator
If the Sportage is fitted with a drain it most likely is only a plastic phillips headed screw positioned low in the bottom radiator tank, my Cerato has a drain of that type. I'm sure a fellow owner will respond and let you know for sure. I think your owners handbook should have a section about it.
I looked up the owners manual, I do not see any information on the drain plug location. I have another car (Hyundai Elantra) and I have no problem finding that plug in it.
Come on fellow owners , is there a drain fitted?
I don't believe this has the phillips head drain plug in the bottom of the radiator. Look on the passenger side of the radiator (easier to view from the bottom). It has a regular drain cock. Best of luck.
I was looking for mine just yesterday. I stuck my head under there and seen a white plug. But my radiator is not the original, it might not even be from a sportage.
I was able to add antifreeze to a full radiator without draining it. I used a turkey baster. While the car was off, I sucked up as much fluid as I could, then added antifreeze. Then I started the engine. Using the turkey baster, I kept taking out and putting in the fluid. Within 15 minutes, I had half the jug in there. BUT the water started getting pretty HOT.
Passenger side, back of radiator at bottom. Mine has "butterfly shaped" things on it used to turn it. I can see mine by squatting at the front right tire, look through wheel weld in front of the tire.
1 - 7 of 7 Posts
