2016 Sportage CRDI 2.0 AWD
Was replacing the left front axle few days ago but after the ABS, Stability control, all wheel drive and the emergency braking warning light are all on. My guess is that I have damaged the wheel speed sensor. Any thought? Also, I´m not getting the sensor out, it there any trick to that?
Thanx
There will be a wiring connection so the hub can be replaced (wheel bearing). You just disconnect the sensor and it goes with the hub. When you replace the hub, you just plug it in. There could be corrosion in it or just a bad connection. Put it together with silicone grease.
