1 - 13 of 13 Posts
2003 Kia Sorento LX
Hi, peoples, I am new here and have a question.
I have a 2003 Sorento lx V6 and need to change spark plugs, the engine has a miss at higher rpm.
What is the best sparkplug I should use?
Thanks
Philip
Thanks
Philip
I'm going with NGK's latest extended life plugs.
NGK 96457 Ruthenium HX
You can more than double the change interval compared to the original plugs in a 2003 model.
The Ruthenium is harder wearing metal compared to the Iridium and Platinum.
2008 SORENTO EX
Or, just go with the OEM installed and you should be good to go...on the 1.5Gen Sorentos (07-09), they came with NGK laser iridium. Because the spark plugs are a pain to change on Sorentos, I would stay away from the 'gimicky' type plugs like E3, splitfire, etc.
2003 Kia Sorento LX
Frustrated now,
OK, Installed new wires valve cover gaskets, the 3 coils and NGK Iridium BKR5EIX-11 plugs,
cleaned throttle body and Mas Air Flow sensor.
Engine Still misses at higher rpm. Idles just fine. wow!
Any suggestions?
Frustrated now,
Any suggestions?
Have you checked the codes - I'd do this as it might flag up something else in addition to the misfire, and if it identifies a specific cylinder misfiring switch the ign coils and see if it moves to a different cylinder.
If no electrical ignition problem is found do a compression test.
Time to take into a professional shop who can hook it up to the mega buck computer and run the engine thru all the various diagnostic tests......
Roon1004.....when I put the part number you supplied at the NGK web site it is not found.
Obviously, your in the know, but how can we order this plug when NGK's own web site does not show the p/n?
Thanks! Lou
Thanks! Lou
That was the part number that appears on RockAuto.com
The below NGK site also lists it for the 2003 Sorento.
113033
2003 Kia Sorento LX
Discussion Starter #9
Compression checed 2,4,6 above 150 to 160 lbs.
See plugs in photo.
No codes present (I have checked 15 times already and just now.
113035
113036
When you pulled the ICV did you check the injector harness plugs?
They get very brittle and can cause a misfire from engine vibration.
2016 Sorento LX V6 AWD
To me, missing at only high rpm usually indicates a problem with the fuel pump. Won't matter which spark plugs you use if there's a fuel delivery issue where the pump can't keep up with the demand at high rpm. Did you inspect/compare the tips from the old plugs? That should tell you enough about what's going on inside the cylinders. But on a 2003, I'd be looking to change the fuel filter first just to rule that out.
2003 Kia Sorento LX
Discussion Starter #13
The old plugs were very waisted, it needed plugs many miles ago, but all were firing, no oil at all.
Fuel....good suggestion for sure, I'll go there next, measure pressure, change filter etc.
Right now I am trying to fix the water reservoir leak, very bad at the seam where the 2 halves join
together it is separating.
1 - 13 of 13 Posts
