hi guys
i've found some alloys i'd like to put under my Pro
what do you think?
1. effezeta fz fiorano 17"
2. kosei seneka rx black polished 17"
i like the stok ones too but prefer to have something special under the car
problem is they are not easy to be found
and the kosei ones are very expensive
so i will be doing some hunting for some nice wheels :p
Hello Stoffe187 Kia wheels are not easy to find because the information for fittings is not made readily available can start by researching Kia models similar to yours to see what wheels and tyres the fit. As long as you go for the large wheels to accommodate brakes there should not be other clearance issues.
Do not search Model confirm your size of wheel and pcd fittings and search those I am only guessing but
17"x7" ET 40 5x114.3 There will be a range of Et you can use depending on tyre choice and how you want to fill between suspension and wheel arch Search 38- 42 if range in individual searches.
Woolfrace and other sites do imaging so yo can put picture in of your car and adjust wheels to fit.
Some sites have better knowledge of Kia wheel fitments.
Jeff
