1 - 20 of 22 Posts
2009 Kia Rio4 dr Sedan LX Manual Transmisson
Hi all,
I recently purchased a Kia Rio as a beater car. This one is literally as simple as they get. No AC from the factory and no power steering either and manual trans. Vehicle runs and drives amazing. No issues in that regards. Motor sounds good even on cold starts. Engine oil is brand new and correct weight. The issue I am having is the dreaded flashing check engine light. I can tell you exactly and how it happens.
I drove the vehicle for a couple days and cruised and drove perfectly attempting to have it just get ready for smog. Vehicle had a dead battery when I picked it up and the monitors were not set of course post the battery drain. All got reset very quickly within 15 minutes except the 02 sensor. After the couple days of normal driving and highway cruising at speeds above 65 miles per hour it was not, I decided it was time to just do the readiness monitor resetting per procedures. I did the the highway cruising thing and that's when the problem pops up. At exactly around 3k RPM's highway speed which is basically 56-60 mph's I will within 30 seconds get flashing CEL. Codes stored will be Cylinder 2 and cylinder 4 misfire detected. Keep in mind the vehicle did not hesitate or show any misfire symptoms but only give the warning. If i reproduce this enough times it will finally give a solid CEL and misfire will be detected. I put in new plugs. Cleaned the crap out of the throttle body as the pedal had a slight stickiness right in that pedal range and I assumed it was causing this. I also swapped coils between the sets and misfires did not move.Throttle body still felt sticky so I got a good used one and now no stickiness but same faults. At time it will also set cylinder 1 misfire detected also. I decided since the faults were showing up on the 02 sensor readiness procedure that maybe it just had a bad 02 sensor. I did the pre cat 02 and same issue is present. I can also replicate the fault on a lower gear and speed but it was around 25 MPH which was also another 02 readiness step per driving procedures. at around 55 miles per hour The vehicle will never set the codes but 02 sensor never gets ready. At any other speeds I get no misfires even at like 75 or 80mph. I am just stumped and I don't want to really throw a bunch of money into fixing this shitbox vehicle I purchased for the sole reason of it being reliable :(
Terrible sorry about the super long post but I like to give as much context as possible. I am considering replacing the post cat 02 sensor but money is starting to add up and I just cant justify it on this vehicle.
Best Regards,
Rekan
Swap injectors around and see if the problems follow....
I might do that next and see. I just feel like if it were injectors wouldn't the issue happen under different loads also? Example being hard acceleration and low RPM high load. The car runs like butter even at 40 miles per hour low RPM fifth gear full throttle. Not an ounce of hesitation or stumbling from misfires. I've never actually felt a misfire on the vehicle. I've also been through about 3 tanks of gas in the process so I ruled out bad gas since it had been sitting a while. I will however swap injectors to find out. Thanks.
I recommend getting a realtime OBD datastream reader (such as Torque for Android) and find out what the live data values are, most importantly the fuel trims.
PS...the post O2 sensor only checks to see if the Cat is operating properly. It does NOT control anything. You can live without it. That is the job of the upstream O2 sensor. Don't know if you can afford the device Kiaguy recommends.... Good luck!
… Don't know if you can afford the device Kiaguy recommends....
Although I bought and have been using a standalone reader unt for a number of years, the most common option these days is to buy an inexpensive dongle and then download a cell phone app such as Torque for Android. It's a very inexpensive way for someone to acquire one of these useful diagnostic tools.
Really? Did not know you could do that, and I recently entered the modern world and purchased a smart phone!
Discussion Starter #8
Yeah I have had a blue driver scanner for over 7 years now and it works well and lets me see live data on many supported items including 02 data and fuel trims and other things. I'm glad I don't need to replace downstream 02 sensor. One less thing to worry about. I'm worried this vehicle has some time of timing issue or VVT Solenoid issue but oil is crystal clear and clean. Usually you see some dirty ass oil for those problems!! Uuuugh I am soo annoyed. I have had the worst luck with Kia's and Hyundai's. My 2015 Sorento has a timing issue now and bad differential. I've owned over 35 + BMW's and don't run into issues like this and they are easier to work on :( Believe me when I say it.
Discussion Starter #9
Also Can someone help me find out what negative markers I am looking for on bad fuel trims? I am going to go on the highway today and monitor them.
Watch what the fuel trim pattern is, particularly STFT, first at idle after it runs for a couple minutes, and then as you begin to drive. When running well, STFT values should be bouncing rapidly around in the low plus and minus single digit range at idle or steady throttle. But whatever the pattern is, try to see if it's fairly consistent below 3K RPM, and then take note of any changes at the higher RPMS.(where you see the CEL come on).
And if possible, try to also see what the MAP pattern is as well. First check the MAP value with engine off, key on, which should of course be atmospheric pressure. Then get a MAP reading at idle and what the RPMs read as well. Then watch to see if anything unusual happens with MAP when the RPMs begin to cross over 3K.
Discussion Starter #11
Thanks for the great info. So I checked idle and it fluctuates very correctly at -3% to +3-5% so it all seems normal. Long term fuel trim also stayed right at 1.6% I believe that is considered normal as well. But with no fluctuations of any kind. I will have to check MAP values as well.
Now onto the cool info. I did not put the vehicle under load aka driving but I did rev the engine. I noticed one tiny and I mean for a fraction of a second blip in Short term Fuel ratio. It read -100.00% on the graph it just looked like one tiny blip. However I believe that was right when I revved it to around 3k RPM's Not sure if that is ever supposed to happen. I have will have to drive it later when it cools down (It's like 95 degrees out here and no A/C on this car :( I got a few other vehicle to work on anyways in the mean time. But feel free to let me know :)
There are a lot of posts of crankshaft position sensor failures, which cause a number of symptoms including misfires. They are also known in a lot of cases to NOT throw a code when they're going bad. Also not knowing the maint. history of this car, the VVT oil control solenoid may be plugged up with sludge and causing VVT problems that MAY translate to misfires. Usually the Intake side solenoid is the "culprit" and easy to remove and check/clean.
Good Luck!
  • Like
Reactions: how easy is it
,,,,, I noticed one tiny and I mean for a fraction of a second blip in Short term Fuel ratio. It read -100.00% on the graph it just looked like one tiny blip. …
Interesting piece of information, but hard to correlate to a misfire code because those normally require some repetition of events to get set. It might also be helpful to capture and post the freeze frame data that's generated at the time the misfire codes are set. One thing of particular interest is to see if the upstream O2 sensor voltage is showing up excessively high, which would match up with the -100% STFT that you just observed.
Discussion Starter #14
Good Luck!
That was going to be my next task today. Taking out the solenoids and cleaning. I have run into that on soo many other vehicles. Just poor oil change history and sludge on the inside of the mesh filters. I am going to do that regardless today and kinda move forward from there. I hope that resolved that issue. I will keep you guys posted and hope for the best here.
Discussion Starter #15
When I go for a test drive today I will run data on the upstream sensor and fuel trims simultaneously and see if there is some correlation. Luckily I know the conditions to recreate the misfire which is good and its not completely random. Do you think that High Voltage at that exact time might correlate some mixture issues. Also when we talk about high were talking about with range like .700 or something like that?
The -100% that you saw is something out of the ordinary, and I'm not sure what the O2 voltage will be - I'm guessing quite a bit more than .7, but I guess we'll see about that. See if you can capture and save the freeze frame data from the misfire codes previously set. Then clear the codes and do another capture when the codes come back.
The other thing that jumps off the page about your situation is the multiple cylinder misfire (with flashing CEL), but no noticeable performance problems. I don't recall ever reading another report like that, and it's hard to understand how it can even happen, because in order to identify misfire, the ECM should be getting sensor input indicating that those cylinders are physically lagging behind the others which are firing correctly. Perhaps some additional live data with the engine under load will show something else that might shed some light on what's going on here.
Discussion Starter #18
Yeah it's just I get misfires on other cars and the car runs like shit you know. This one runs like a champion I mean in 5th gear its very easy to peg the gas pedal and go from 50 to 80 in a very reasonable pace and it will spin tires from a stop and rev to 6k with no problems and idles perfectly. I was working on my sisters Chevy Cruze yesterday replacing the turbo on it and didn't have time for the rio but today is the day. I am cleaning out the solenoids and I will drive it and try to record some live data and see.
Discussion Starter #19
Update still no information worth sharing from live data. I am going to call Kia as there was a TSB to address misfire codes randomly appearing a few years back and an update done to the ECM's to resolve it. I am really hoping this vehicle hasn't had one done. So that's my only next alternative. Wish me luck any other input would be nice. Even though the coils looked brand new I went ahead and installed another set and the problem didn't resolve itself.
Discussion Starter #20
Update again. The TSB is not covered and I would have to pay for them to just check to see if it was even performed. Kia dealerships near me all 3 of them are complete and incompetent morons, I am sorry but they cannot even tell me if the vehicle has any recalls and tell me they will call me back. I tried to just make an appointment for diagnoses and they said they would have a service advisor call me back. No one ever does.. Honestly I am never going to buy a Kia again in my life. Waste of money on every occasion I have done it bullshit issues with my Kia Sorento also. I am at a loss. I checked for vacuum leaks. Couldn't find any. Cleaned the MAF or whatever it is and that didn't resolve it. Vehicle has 4 new coils and 4 new spark plugs and issue is still persisting and replacement throttle body. I did a complete battery reset last night to drain the PCM and drove it again today and still nothing. I cleaned the VVT solenoids too and still no resolution. Oil is changed and clean as well. I worked as a service advisor for 8 years at BMW and we never had issues like this. My techs would find an issue and if it was tough we always had a way of solving it. I am telling you I've seen everything that could go wrong with any car and I've never had an issue as stupid as this Kia Rio. Any other information would be great if anyone has ideas. If not I am literally and I am not joking going to ditch it on the side of the road. I'm fed up. Car runs and drives great and you can take it to Vegas and back and Ive had it running for hour and hours without any mechanical issues. Sorry guys if I am being negative but I am just soo upset.
1 - 20 of 22 Posts
