Interesting issue here. I have an 99 sportage that has been very used. The issue is, the power windows are very very weak. Driver side front works best (goes up on its own), the passenger side is next but does not go up with out help. The rear windows are both very weak and barely go down, much less up without help.
Based on the fact that they do work to some degree, I assume fuses and relays are good. I also checked battery and alternator, both good. Is it the individual electronic motors going out? Any ideas?
