2008 Kia Rio LX
So bought this little car last feb. 300000km had wicked good heat. motor barely uses oil it runs like a champ. My Wife drives it way more than i do. anyways i did the timing belt and cam and crank seals and water pump last winter. This winter i drove it one day when it was cold out and such poor heat! BUT on highway with engine rpms higher.. great heat. Temp seems normal but i bought a new hyundai thermostat to install when i get a chance.
My question is this. has anyone had this issue?
Im beginning to wonder if aftermarket water pumps are not flowing coolant at idle as it should.
I will be flushing heater core when i do thermostat, but i am wondering if i should buy an oem water pump and gasket and swap it as well
2008 Kia Rio LX
update .. found there is heat but only on passenger side. drivers blows nearly cold air. this has manual heater controls and service manual does not offer a view inside the heater box.
I wonder could half my heater core be plugged and not warming the air? i doubt the blend door is a two piece unit like cars with dual climate zones but im not sure
2008 Kia Rio LX
flushed heater core today .. built a flushing tool with copper fittings and blew compressed air and water through heater core . then filled with clr and used a boat live well pump to circulate the clr. flushed again and once more again backwards. YAY heat fixed!!!
