My Soreto 54 model has developed a water leak in the rear window.
The window has two leaks, both leaks coming through the hinges. Although the leaks are small, the car is going in for repair soon.
Has anyone else suffered similar problems and what was the outcome?
Regards Mike. :mellow:
My 04 Sorento suffered from the occasional water leak through the rear window seal, the problem seems to occur if the seal gets dirt and grit between the tail gate window and the seal, I make the point of wiping the seal and window round every time I wash the car and this seems to have cured the problem. Applying a small quantity of silicone grease to the seal also helps to keep the seal plyable.
