1 - 17 of 17 Posts
I have water accumulating in the rear cargo area floor where the back seats go into the floor. The water even accumulates when the van is sitting in the driveway when it rains. Are there drain plugs anywhere that I can clean and resolve this problem?
please gentlemen fill out your location and drives profiles, it makes it so much easier for us to answer questions.
2012 Kia Sedona LX
I am having this problem as well with my 2012 Kia Sedona LX
I attempted to locate the problem using a garden hose and focusing the water on specific areas but I am not having much luck with this.
I suspect that its leaking from the top area of the rear door, either the antenna mount or perhaps the roof racks but this seems somewhat unlikely due to the volume of water entering the cargo area.
After about 30min of intermittent testing I managed to suck out nearly 2 cups of water from the floor area with my carpet cleaner.
I am planning on calling my dealer tomorrow but due to the difficulty I'm having finding the leak I suspect that this might be lengthy visit for them to isolate the problem.
Any suggestions?
2009 KIA Sedona LX
Any suggestions?
should be fixed under warranty I would think.
2009 Kia Sedona LX, 2008 Hyundai Sonata
I have a 2009 Kia Sedona LX. We just had a torrential down pour for 2 days, and I have water pooling in the cargo area. Did anyone involved in this thread find the leak?
I think I may have nailed this one.
2 Years ago I was rear ended in my Sedona, and I was having leaking issues ever since - especially after heavy rainstorms. I went back to the body shop twice, but they couldn't find the problem.
I noticed water was coming in from two screw holes on the driver and passenger side where the wiring harness at the back wall clips in. They sealed the holes with silicone during my second visit.
I finally decided to pull the bumper cover off myself, and within 30 seconds I found the problem that eleuded them for 2 years. About 4" below the tail lights there is a ledge where 2 metal seems meet. On both sides there was a noticeable gap in the seam in the corner, that was right where water was flowing!
Finding the same water in the rear of my 2007 Sedona EX with a factory sunroof. Tracked the leak to the passenger side rear sunroof track drain. The rearmost part of the track has a plastic stop that funnels water into the drain hose. The problem appears to be this funnel leaks before the water gets into the hose and I can't figure out how to even remove it let alone repair it. I really hope I don't have to always remember to park downhill in the rain.
Use compressed air to blow out the sunroof drain hoses. That's the easiest way to clean them.
Sedona 2012
How was it fixed?
How was the problem fixed? Did the body shop repair it? I am having the same problem. My Sedona was rear ended and repaired back in July. There has been a leak ever since. I am hoping the body shop will still repair the problem.
2007 Hyundai Entourage, 2007 Kia Sedona, 2005 Infiniti Q45, 1971 Buick Centurion Convertible
2007 EX Sunroof Leak-Are There Rear Drain Channels/Holes?
Greg:
I've copied something that you wrote in reply to a post from 5 years ago. Do you know if there are rear drain channels/holes in the Gen II Sedonas? If so, were are the exits so I might blow compressed air backwards through them to clear any blockages?
Sedona, 2010: Forte, 2017
I found the leak in my Sedona was coming from the gasket between the rear bumper and the body where it attaches. The vehicle was rear-ended and after the repairs there must still have been some minor damage that led to this mismatch.
Water would leak in and then, if the vehicle was at the right angle, enter the cargo area when the channel (that a tow bar would attach to) filled up sufficiently before the drain holes could do their bit.
I tracked down the leak by using a bore-scope camera and following the water back to the source. Took a long time to eventually track it down. Fixed it by replacing the gaskets with thicker ones I made myself.
Kia Grand Carnival / Sedona
Water Leak in Cargo area - Found cause
Well, this has been a problem for some time for me. First there was some small amount of water leaking from the cargo door stop light. Got that fixed. Then found a huge amount of water was entering the cargo area and was baffled where it came from.. It happened a few times and never really found where it came from. I finally nailed it by opening the sliding doors and felt the carpet on each side and to my surprise found it was wet on the right hand side near the door where the carpet was... Upon close inspection, I noticed where it was coming from. You can see drops underneath where it was coming...
I got a camera up all along there to have a closer look and it seems to be that the rubber seal had a bit of foreign grit all over it from sand, dirt etc.... So I have now wiped all the rubber area underneath the door sill (white flap) and also proceeded to wipe the entire black rubber seal around the whole door and the metal area where the black rubber seal meets the door frame when it closes. Over time it has picked up dust and dirt... So its all clean now.... will see if that fixes the problem. If not, I will be changing all the rubber seals. Note that the car when parked is on a small slope, so the water runs down the back into the cargo area.
I am fairly certain this is the main cause of cargo bay leaks apart from the leaking stop light seal
As a good measure, I recommend all Kia Carnival or Sedona owners to run over those areas on both sides for good preventative measure...
I am interested to know from other users if this has resolved their leaks...??
My car is a late 2006 Kia Grand Carnival with power driven doors
2011 Kia Sedona
After checking many possibilities of why then back cargo area of my 2011 Sedona was flooding I cut and ripped up the gross carpet to investigate. Put on the hose and wet down the back of the Sedona. Both bottom corners of the tub closest to the back lift gate had minor rust holes in them. The water was flowing in through those. I have attempted to fix using black silicone from the inside as well as the outside under the bumper. I know this is a temporary fix and just hope it stops the water from flowing in. So I will wait for it to cure and test again. Then it will be time to put some carpet down back there and get back to normal. Hope this helps!!
Moderator
99 Kia Elan 1.8L
Using the below link, please add location and vehicle (year & model) to your Profile/Account Details
eg.
USA
Kia Forum
Forum Rules
1 - 17 of 17 Posts
