86 El Camino 2002 Kia Sportage
So after following the advice on here and removing and cleaning then re-greasing my hubs, I still don't think they are working right, the back tires still spin with the front tires doing nothing.... But I still don' think it is the transfer case, I still believe it is the hubs, So after I cleaned them I took some pics of them in the locked position I just don't think they look like, but I have no clue so I thought i would see what you everyone thought. the pictures of the inside of the hubs they are in the locked position. Also when i took one off I found this small metal sliver in the hub, I put a picture of it on here as well. Also one more weird thing, the hub selector never goes all the way to the free position seems to stop right before it no matter how hard you twist, that pic is on here as well. So what does everyone think??
Auto part Wheel Bearing Rotor Locking hubs
Close-up Macro photography
Auto part
Thanks now for any answers
The piece of metal looks like a piece of one of the internal compression springs.
One way to test the hubs is to install them in a vise . Install a wooden dowel or a screw driver handle in the spline snugly. The handle /dowel should rotate freely in the free position and should not be able to turn it in the locked position. Test both hubs.
A broken cam or spring may be your problem.
The hubs are purchased as pair. Check out Street Side Auto or Amazon deals.
Hope this helps.
chief
