Hello,
I have a 1999 kia sportage 5 sp. 122K that sat for about four years in a field. I have worked all of the bugs out but one and it is driving me crazy. It cranks excessively only after it sits for about a half an hour after being fully warmed up.
The past couple mornings it has been in the single digits and it starts fine, five minutes after it sits it starts fine, the only problem is when it sits for about a half an hour, it takes about ten seconds of straight cranking to fire up. If you let off the key after about five seconds and come right back at it quickly, it will fire right up. After it starts, it runs great, lots of power, it you shut it off right after it just took ten seconds to start, it will start right up perfect.
So far I have swapped out the two relays under the hood from ones I found at the junk yard will no change in performance. I checked the voltage to that maf to see if it was full battery voltage and it was. I cleaned the ground by the battery and the fuel pump itself. The engine has new coils, plugs and wires. I have swapped out the water temp sensor with one from the junk yard because I was getting readings averaging 185 from my reader. Both sensors read the same, low, I don't understand, maybe it is my reader. I put a new super stant thermostat (195) in. Fuel filter was replaced a couple days ago. No check engine light. I ran some lucas fuel injector cleaner and some dry gas through the system.
Any ideas would be greatly appreciated.
