Does anyone know the color of the VSS wire and its location on the ECM?
The vehicle is 2006 Sedona.
2004 Optima 2.4 EX, 2005 Yamaha R1 (street) 2001 GSXR 1000 (track)
Well assuming you are talking about a U.S. model, it's a 3 pin connector. Pin 1 is red (power), 2 is green (connects to pin 34 in the engine room junction box, connector BCM-FC), and 3 is black (ground to body). Unfortunately, most of the communication on this vehicle is through the CAN network. There is no direct wire from the VSS to the PCM. What is the concern you are experiencing? Please fill in your profile so we can better assist you.
I think the best bet would be to hook directly onto the wire from the VSS connector on the transmission.
