1 - 8 of 8 Posts
2015 Kia Rio
Anyone have this issue? 2015 rio, I’m only getting 4volts to my compressor. If I jump power to it everything works fine. Diagram shows power comes straight from the a/c control unit. Is this a common failure ?
Drives : Nissan NV200 Flies : Rans S6ES
Sounds like it's a variable displacement compressor that is controlled by a pulse width modulated signal from the control module.
So, is the compressor really only getting 4V, or could it perhaps be a 12V PWM signal that just looks like 4V on a DC voltmeter?
2015 Kia Rio
Had a dc meter in the connector. My wiring diagram didn’t specify it was pwn. I had assumed it was straight voltage. So this is a variable vain compressor?
Your description of the circuit suggests a variable displacement compressor. A clutch type compressor would only have a single wire on the harness connector. And that wire would come from the compressor power supply relay on the engine bay fusebox.
2015 Kia Rio
Discussion Starter #7
Does this have a capability to view live a/c data or activations? My solus only picks up automatic a/c but this car is manual. I also noticed there is what seems like a diagnostic connector under the hood but I don’t have a adapter for that
Sorry, I've never had to diagnose a fault on a Kia AC system so I don't know the answer to that.
It really doesn't matter whether you connect the scan tool to that connector or the standard OBD connector on the dashboard. The tool is connected to the same CAN BUS on either one.
1 - 8 of 8 Posts
