2007 kia sedona ex
Im trying to find the voltage regulator. 07 sedona ex. Have been chasing issue with headlights flashing park and brake indicators flashing. Doors not opening electricly. And not shutting once opened. Etc. A real ghost in the machine. The ig2 relay is clicking loadly when it stops the low beams come on. Then they go off and the ig2 starts clicking again. Was looking for the voltage regulator to swap to see if it may be bad. I have replaced both headlight and wiper switches forgot to mention wipers only work on low. Replaced temporarily the ecm as a big swing. No change. Thx.
Drives : Nissan NV200 Flies : Rans S6ES
The voltage regulator is an internal part of the alternator.
Have you checked the alternator output voltage? You'd probably want to do that before swapping the regulator, even if it wasn't buried inside the alternator.
Autospark is correct!
It's built in to the alternator.
Some are very difficult to replace. If yours checks out bad I recommend a rebuilt alternator R&R.
