- The mileage is 6779, fully service last month , pressure switch wire fused together was repaired , injectors pumps selonoid switch fuel filters were all changed does not start easy the check engine lamp is on
6,779 km is extremely low for a 2005 model.
1) What engine, V6, I4, 3.5L, 2.4L, ...........? - put that in your signature as previously requested.
2) OK, serviced last month, but what it the service history?
3) What pressure switch wire was fused together?
4) When was the injectors, pump, solenoid, switch and fuel filter changed, ...... before the incident, or after, ......... on what basis were these parts changed?
5) If the check engine lamp is on, what's the error codes?
6) When last was the timing belt changed - has the timing been checked?
