I want to replace my upper ball joint but I don't know if its is integrated with the upper control arm or not I have a 2000 kia sportage base model a diagram would be nice. thanks
All one piece , the top mounting bolts have a cam washer for adjusting the caster an camber . Mark there position with a paint line before removing and installation. Remove the ball joint bolt completely. Realignment may still necessary but you will be close.
Check out kgis on internet explorer only also kia discount parts the have some exploded views that help you.
Check the other side also, only one alignment that way.
any idea if 2nd Gen sportage(or other car) side mirror are compatible or does it fit to our 1st Gen? I'm having a hard time finding 1st gen side mirror here in our country.
2000 Kia Sportage 4x4 2.0. The vehicle ran fine and I stopped at the store come back out after about 2 hours and no start. I have checked everything , tested fuel pressure , spark, and keep getting 1307 code. Replaced sensor checked for continuity and all is fine.
I just don’t know where to...
I Want to store my summer tires but I don't know how to remove the wheel hub cap. My car is a 2001 Kia Sportage.
Below 2 pictures from the tires (outside and inside)
Thanks in advanced for your help.
I purchased manual locking hubs for my 2002 sportage and after reading reviews it requires shorter mounting bolts, anyone else purchase a similar product and need the shorter bolts? If so what size and length? I'd like to have them prior to new hubs arriving so I can just throw them on. Thanks.
