141 - 160 of 171 Posts
"headlamp washer"? is there is washer for that?
He has HID (Xenon) low-beam headlamps.
Headlamp washers and auto-levellers are requirements in a lot of countries.
Along with the auto-levelling, a lot of European cars offer turning lights aswel. (I.E. Point around corners - not to be confused with cornering fog lamps)
2012 Sorento EX AWD CRDI; 2007 Sportage EX CRDi 4WD; 1967 Mercedes 250S; 1958 DKW 3=6
yes,that is correct!
White 2012 SX AWD
With the navigation unit, when you go to select destination, there is an Emergency option. Never tried it until today. Could be quite useful, especially in areas you're not familiar with. Lists:
  • Police stations close to your location
  • Hospitals close to your location
  • Kia Dealers close to your location
As for the head lamp washers and auto levellers...I'd love to have those!
He who dies with the most toys wins!
Actually they are not that useful. At least not in the tropics.
Sorento 2012 EX V6
Red reflector bottom inside front driver/passenger doors
Does anyone know whether these light up at night, or how, if possible to get them actually hooked up to power to actually emit light. I am thinking that this must be a safety feature offered for oncoming cars to see that a door is open, however, my brief experiment with a flashlight at night really doesn't reflect a darn thing. Can anyone enlighten me please?
EX V6 AWD 2012.
EX V6 AWD 2012.
Door lights. Front only.
Jan-2010 Si
Korean-built.
2012 Sorento SX-V6 FWD, Nissan Quest 1996, Hyundai Elantra 2000
EX V6 AWD 2012.
I believe they are called courtesy lamps. They light up when the door is open similar to the cabin light and are found only on the front doors.
White 2012 SX AWD
My 2001 Santa Fe was the same. Different markets had slightly different things. Mine had grey inserts. Behind that was wiring and bulb socket. I ordered the red reflector, put in a bulb and they worked. Later years removed the wiring as others tried but could not do this.
Maybe the Sorento is the same?
Ah. So you mean if we peek under the red reflector (on Sorento), there may be a revelation..
White 2012 SX AWD
I'm hoping so. I may get around it at some time...maybe in the summer when it's warmer and there's more light!
2010 Audi Q5, 2012 Sorento SX
This is documented in a post card I found underneath my seat that must have fallen during prep, and I am not certain this is documented in the manual, but if you have an interior lighting package, you can hold the button for 5 seconds in the center console (by the gear lever) to turn on the automatic color change cycle and push once more to set to one particular color or off.
Hmm. I should check this tomorrow..
Sorento 2012 EX V6
Pretty sure that before posting my original message, I slightly checked the reflectors and couldn't see anything to unscrew on or near the reflectors, and that's why I launched the question as to it's usefulness. Perhaps a pry open, but that might break the reflector. it would be such a shame to find out that they were dummy reflectors, however I suspect they are because there doesn't appear to be any switch associated.
There can not be switch as it should illuminate when door is opened
May be there is no bulb. Just the holder. Put the bulb and voila.. :D
White 2012 SX AWD
With the Santa Fe I had to remove the door panel to get behind it. Only after that could I remove the insert and replace it with the reflector. Best way to find out is to try!
2013 Sorento SX
I was happy to find that the USB plug actually provides a charge, so I'm able to charge my cell phone off of it. It doesn't charge fast, but at least it works.
