2000 sephia
it appears i need to remove the fuse box so i can replace my clutch master cylinder,if that is the case i need some tips on getting the box out of the way.i removed the 3 screws that hold the box to the body of the car and now cant figure out how to gain enough room to get at the cylinder.all help is appreciated.
there is a lock tab on a side of it and ground wire.
The Wire on the Box's side, marked as B+ is Hot (12V +) Be Careful!
I Kindly suggest you to disconnect the Battery terminals, prior to try the Removal procedures.
Also, the Screws INSIDE the Box are holding together both parts of said Box, so they're to Split the Box and service the connections it has inside.
Kind Regards.
