1 - 10 of 10 Posts
2011 Kia Sorento
I bought my 2011 Kia Sorento about 2 months ago. My dash turn signal lights indicated I need a new bulb. (Blinking quickly) Eventually Stopped working so got a new bulb. (front left) So the old bulb looked perfectly fine which I found odd but whatever I still changed it and It worked fine. Then a few hours later started blinking quickly like before but the bulb still worked. Now Less then a week later it doesn't work at all. I checked both fuse boxes and saw nothing that referred to my turn signals at all. I even went into the cars manual and saw nothing. Now the weird part.. when I unlock my car the signal still lights up. When I turned on my hazards it works to. It just doesn't work when I use my turn signal. So now I have no idea what my next step should be. Any advice is appreciated thanks!
White 2012 SX AWD
I've seen or heard this happen when someone changes some of their lights to LEDs. I think it has to do with a different load being put on the circuit. I've also heard it could be one of the modules. I'm not saying it's either, just saying that Ive seen, heard or read about those. Good luck.
Try spraying some WD-40 on it, the socket, or the bulb. See if that helps?
2006 Kia Sorento
2011 Kia Sorento
A similar thing happened with my Sorento. It was the turn signal that was shorting out and causing the headlights to flicker during a turn with the blinker on. Scary at night time when your headlights cut off. It was a faulty turn-signal "cap" that the bulb attaches to.. the little metal prints on the outside of the cap that contact the electrical leads on the headlight turned out to be burnt/sorted out and was slightly sorter than normal. I trip to the "stealership" for the cap and $26 later. problem fixed
2013 Kia Sorento LX V6 AWD
What did this wind up being? I am having similar problem with my rear turn signal and running lights.
Hi. Did you ever find out what the issue was? My 2013 Sorento is having a similar issue. Driver side front blinker and running light not working, bulbs replaced. However, the front driver blinker works when headlights are off, strange. The blinker rapidly blinks when I try to turn that direction. Also, my rear passenger tail light has a dim running light, no brake light, and no working turn signal (bulbs replaced too). On top of it all, all my system lights occasionally dim and slowly dip up and down (very strange at night). Hope your car is working now :)
Drives : Nissan NV200 Flies : Rans S6ES
That means the ground connection is bad. When the headlamps are off the turn signal's path to ground is via the running light circuit. But when the headlamps/running lamps are on that path to ground is broken because the running light circuit is now at +12V.
This fault is usually caused by a poor connection in the bulb holder, so the first thing I would do is try bending the ground contact in the bulb holder out a little so it makes better contact with the bulb. I'm not familiar with your particular model of car but I assume it has a bulb holder similar to the one shown below. Look for the little brass finger highlighted in the photo and use a small screw driver to pry it out a little. See if that helps.
If I helped you fix it, why not...
Your support is greatly appreciated
1 - 10 of 10 Posts
