Kia Sephia 2000
I got this po343 code (Camshaft Position Sensor "A" Circuit Low). I took out the camshaft position sensor out and inspected wiring and the sensor itself. On the magnetic part of the sensor, it looks like small lumps and I cleaned the wiring and the magnetic part of the sensor using electronic cleaner. I then reinstalled the sensor and connected the wiring. Cleared the code and disconnected the battery(negative cable) for a few minutes.
How did all these problems began? On my last post concerning the PO460, fuel pump sensor that connected to the fuel gauge level, (stuck needle on full tank). I am still trying to resolve that issue. My point is po460 is somehow related to this present po343 code? Also, I noticed when trying to start the igntion, I had to turn on the ignition to start several times before the engine runs. Normally, I turned the ignition to run the engine one time, not several tries or times as it is doing now. Any comments, advice or feedback is greatly appreciated.
Kia Sephia 2000
Discussion Starter #2
Today I got the new camshaft position sensor. After replacing the old camshaft position with a new one, I started the sephia and the engine run after a couple of turning over and fired up. I noticed when driving there is more power and runs like a champ just like before. Currently there is no troubleshooting codes at all.
