Do you guys tow with the tranny in drive or use the manual shift feature? I'm curious as I was told with my older GM 3 speed w/OD to leave it in third when towing.
Thanks,
Rick
10 Optima LX, 12 Sedona LX
Like Sauron said, probably best to leave it in D. These new transmissions and control units are quite a bit more sophisticated and monitor a lot mot data from the vehicle, which ensures it will be in the optimum gear for the situation. The main reason for using 3 in your old GM was to prevent transmission overheating from the high load/low RPM in OD while towing.
What old GM did you have?
Thanks for the replies, I figured it was like comparing apples to oranges. The GM car(s) referenced was a 2003 Grand Prix and a 95 Buick Regal (3.8).
Rick
