Hello
I own a 2007 Kia Sport age 4x4 with a 6 cyl I bought it a year ago and never had any problems with it until the past couple of weeks the transmission is shifting hard and the transmission fluid shows it is full. Any thoughts on what it could be cause i have only put around 6,000 miles on it since i got it. It has 66,000 miles on it.
Also I just noticed I can smell antifreeze after i park the car but not during driving any thoughts on what that could be?
Thanks Kim
1995 Procharged Mustang Cobra,2006 Grand Cheorkee limted Hemi. 2021 Sportage S nightfall package.
What does the trans fluid look like? Red? Burnt? Black? As far as the coolant goes you will need to check the fluid level....VERY important only check when engine is cold. You can look for coolant on the ground after you park.
Cerato S Hatch Auto
Not sure what you mean by "Shifting Hard".
Coolant might be leaking from overflow system. As above, check level in overflow tank and radiator. Run car with heater ON and OFF, look for leaks.
