For anyone outside North America with a Sorento equipped with the factory Towing Hitch (5000-6200 lb capacity), I would like to know if it is the same as the North American hitch. If you have a photo that you could post that would be greatly appreciated.
Also, the Sorento has 7 pin trailer wiring (ground, battery, brake lights, tail lights, turn signals, back-up lights) in the vehicle harness but in the US only a 4-pin connection at the hitch which operates through a "converter" becasue of the turn lamps and stop lamps using the same bulb on many american trailers.
Does any body know of a 7-pin connector that brings all 7 connections to the hitch?
THANKS VERY MUCH.
THANKS VERY MUCH.
